How to create custom saved isometric views
In the attached part, when the view is set to Isometric, the part is oriented such that the green face is normal to the screen.
How would I create a saved (“New View”) that is an isometric view with the blue face normal to the screen?
Note: For this exercise, I do not want to change the view orientation (“Update Standard Views”) or use projected views inside of the .SLDDRW.
Thanks.
custom_ISO.SLDPRT (61.4 KB)
Here’s a super old macro that I’ve used.
8isoviews.swp (26 KB)
I have used a macro too for that purpose.
  1. It’s awesome that such a macro exists and that you shared it with me. Thanks.
  2. It’s not awesome that such a macro needs to exist. The ability to establish custom isometric views should be built into SolidWorks.
you could manually rotate the views and save them into your template.
SW has some default standard views, that fit most use cases, but there are places that prefer to use a dimetric projection or others in place of isometric.
Including all the possibilities in the software would be eccessive, api and macros are there for that reason.
Is there a way to rename saved views?
Not directly. There’s an SPR requesting the ability:
SPR632849 - Ability to rename a saved view in the view orientation dialog or the view orientation list in the heads up toolbar
As a workaround, you can use the space bar to select your named view, and then immediately create a new named view, giving it the correct name and then delete the original. Not ideal if you have to update a bunch of drawings, of course.
to create a view with the blue face I hit the space bar pick the blue face you are looking for. Hit the space bar again. and pick the icon marked
give the view a name and hit the save button.
hit the space bar and click on the opposite face to get the view you want, then save it
Our parts are often long and narrow. I make my own ‘nicer’ (IMO) iso views that fit on the sheet better by taking up less room on the sheet and are a bit less extreme perspective. iso1, iso2, iso3, etc…
Choose a view of the part that is oriented more towards landscape. If the part is more portrait oriented, use the ALT-arrow kets to rotate it more horizontally (default alt-arrow is 15° per click)
Using the left or right arrow key, click three times
Using the up or down arrow key, click once
Make the view
If you want a view of the other side… reverse above steps to bring it back to the original view of the part that is oriented more towards landscape (that you started with
Use the shift-arrow key twice to spin the part 180° around the vertical screen axis
Using the left or right arrow key, click three times in the direction you want
Make the view
That is what we used to do for some parts back in the day. Now the cube has more areas to pick on that make that kind of an older way of doing things for me.
Yeah, I get it… old habits die hard; I never use that cube because it’s cumbersome, but the cube almost gets me to the above way with only one down arrow click to go!click
I like Onshapes and Inventors view cubes, I wish SolidWorks would replace the lower left triad with something similar. The SolidWorks spacebar dynamic view selector cube is a mixed bag. Its actually really good except on really big assemblies its sluggish and slightly disorienting with its zoom out in perspective mode behavior.
What about Dimetric and Trimetric Views? Is there a definition for the various non-normal views? I remember in Solidworks R14, you could specify a view by entering the angles relative to the World Coordinate System.
