I want to be able to see the difference between the last PDM system rev that shows up in the history for a file (stamped rev) and the custom property / variable “revision” that shows up everywhere else (the drawing, data card, etc.).
Is this possible? Right now the Rev column just shows the “revision” variable, not the PDM system rev. I’d love to be able to see them both to make sure things are set how they should be because they keep getting out of sync on some files.
For this I would just use two different variables and utilize one as the “working revision” and one as the “released revision”.
The released revision would be set only when a document is issued and wouldn’t be mapped to any file types (i.e. model custom property).
Then, you can create a column for both the working rev and the released rev. Unfortunately, the PDM revision isn’t directly linkable to the column view so a workaround like this is necessary.
