In this very simple sheet metal I need to add a chamfer to the blue edge. It doesn’t go through the whole length. So I can not use chamfer or break corner tools.
Drawing a triangle and using it for cut-extrude cuts the whole thickness and will result to this.
Is there any other way to do this? How can I add a chamfer to an edge of a sheet metal that doesn’t go through the whole length, but a part of it?
thank you.
