Helical / swept surface intersection curve
Hi All,
I’m trying to re-model this feature (see image), so I can create various lengths.
I’m having trouble with the swept surface/3D Sketch, where it does an offset instead of a straight line to connect.
Does anyone have any suggestions on how to fix this?
Thanks,
Mike
Helical_Sweep_Models.zip (608.8 KB)
Are you saying that you want the “vertical” parts to be straight like your image instead of “squiggly” like your model?
Josh,
Yes, I want it straight.
Thanks,
Mike
This took a bit but I was determined to make it parametric. Layout sketch drives the size and locations and is the base for the projected curves. Wish SolidWorks would enhance the old curve functions so they didn’t need dedicate sketches but not a big deal. Created global variables and linked the dimension to them to control pitch and length.
Spring Obround.SLDPRT (842.0 KB)
Mark, I’m sure you know a better way to do this…please share :laughing:
Jason, looks good to me - that’s how I’d probably accomplish it. Good Job - especially on the equations!
mark
Cool, thanks Jason!
I like how you did that. I got so focused on trying to make the other method work and got locked on that path. I’m glad I took a step back and posted here to get a fresh perspective.
I couldn’t open your file (using SW2023), but I should be able to recreate it.
Thanks,
Mike
I tried saving it back to 2024 but the sweeps got a little wonky when I open in 2024. Recreating them is the only way to fix. and the Equations error but I don’t see why so they may need to be recreated as well. Apparently the save back versions has issues.
