Below is a snip from a dimension. The hole is a C’bore with a thread at the bottom of the C’bore. I’m pretty sure I could do this with an advanced hole but this is off our product line and historically we’ve done/designed this with a Tapped hole and an Extrude cut.
The “Hole Callout” shows the tap and Qty. The other dim calls the C’bore. I’ve grouped the two dims together but I would like to get rid of the secondary leader. I did not see an obvious way to do this but does anyone have a better approach or just someway to hide the second leader?
Hmmm, I’ll have to play with that. I was thinking about that as a potential answer but I don’t know that I have ever done a note with tolerance. I know I can display the dimension but I’m not sure I can get a note to show a limit dimension that isn’t manually entered.
I think instead of hiding the note leader, it will be better to link Dimension 1 and Dimension 2 to the note
After that hide dimension 1 and dimension 2
