There are a few options there that I normally would have left as default, but recently I got involved with more SM designs and I am wondering about whether leave Corner Treatment Option On or Off (it’s on in SW default templates).
This is how I interpret it after researching about it: (though there aren’t many topics about this) it manipulates the flat pattern where bends meet (presumably for manufacturing purposes? to create a clean profile) but at the cost of flat pattern not matching 3D model, which to me is a very bad practice. My confusion is why then it’s left as default and is there really any benefit to it when it comes to manufacturing?
Can I ask you to please create a sample model, experiment with this and let me know your findings? (all it takes is a part with two flanges)
Seems to me it’s getting rid of the relief which is desirable to have at corners, but if those parts came okay then I guess somehow fabricator make it work
It depends on how you want the corner.
Will they be welded? On outside? Inside?
You add corner treatment to get what you want.
It’s not about material thickness. I’ve done the same with 0.5 in plate.
It depends on how you want the relief in the corner.
I know we are deviating a bit from SW related topic, but what I meant about depending on material thickness is that for thick gauges or plates not having any corner relief (corner treatment on) is not recommended.
In my case I don’t have any welding - in cases that I have welding I probably also go with “Corner Treatment” on to keep the gap as small as possible so welding can easily be done.
All I can say is that corner treatment is getting rid of the relief. It should be noted that if you actually have a corner relief feature added then corner treatment on or off doesn’t affect the flat pattern.
This is a 3mm sheet with 3mm inner radius, pretty typical.
Corner treatment is on, how can this be bent without tearing material. Only way that’s possible is going with smaller inner radius.
I don’t know man, to me you can’t get the formed shape from the yellow (flat) without tearing that corner, it’s physically not possible.
I don’t dispute you got your parts well and good but I have to think maybe fabricators adjust things as needed to make it work or add slight reliefs (so long as final formed shape OAL size etc. is maintained), or using smaller inner radius. I’m very curious about this and will reach out to some fab shops to get their opinion on this as well.
To me corner treatment is altering the model by getting rid of the corner relief, somehow similar to to the simplify bend which alters the curved edges to straight ones only in your flat so one can be sure the bent real life version won’t be curved (again I think to ease the cutting with laser, etc. easier as it works better on just a straight edge).
Thanks for the info and the last picture, I think this was a fruitful conversation and will be helpful for future visitors considering there aren’t many info on this on the web, I appreciate it.
I want 3D model to match the flat pattern so no corner treatment for me.
Edit: In fact @David_Matula already added this to 3DS forum under tips - we made the news.
Regarding corners, usually this isn’t necessary unless you are doing 3d renders and just need the formed part to look exactly how it will look.
The flat needs to be whatever it needs to be for your manufacturing process and environment. We sometimes have to add features just for flat to get it the way mfg wants it. They are looking for the simpliest and most cost effective way to fabricate the part. We have many examples like @Frederick_Law has shown. Thin gauge parts with closed corners and no corner relief. They are thin enough that the corner deformation isn’t too pronounced and material cracking it not a concern.
I usually leave if off, since our laser/press break unbend software adds relief when the flat pattern is unfolded in it, so I don’t need it on the model.
The issue becomes on thicker materials that corner can get pushed out quit a bit when bending since the material has to go somewhere, and it’s generally going to go parallel to the punch/die (the whole fluid material path of least resistance thing). Thin parts or parts in softer materials you can generally get away with no or minimum corner clearance, but thicker and harder materials it will crack or actually break at that point with no clearance. So it really depends on what your parts are and what process you use to make them.
There are also such effects on thick foil (in the photo, bending 10 mm steel (millimeter!)). On the slots that fall on the bending line, the metal is pulled into the stretching zone, and squeezed out inside the radius (not visible in the photo).
This is also not reflected in the 3D model, and those who work with flexible thick foil have to take this into account in their heads, adding an experimentally determined gap.
