Elusive geometry problem on outside/inside angle gauge
This one has me stumped.
In the attached Pack & Go, the 8575-10-06_AG part is intended to be an outside + inside angle gauge for 8575-10-06. The “outside” half of the gauge works fine. The inside half, however, has a gap (please see the screenshot below).
Upon opening Sketch1 of 8575-10-06_AG, you will note that I effectively recreated the inside edge profile of 8575-10-06 on the “outside” of 8575-10-06_AG. So, in theory, the gauge should nest into the inside corner perfectly.
What have I missed?
Thanks for any help.
as8575-10-06_AG_PG_20260401.zip (403.5 KB)
Your assumption that this is a 90° angle is false.
That edge is wrong.
Acturally OD radius is on wrong center. It didn’t line up with the straight edge.
As usual, you’re off by 1 thickness.
Ah. That was it!
Thanks!
“So, in theory, the gauge should nest into the inside corner perfectly.”
Unless it is used to check that a corner is inside a tolerance range.
