Efficient Assemblies
Assemblies can be made for several reasons. You don’t always need to allow motion, in fact there are times your assemblies (in-context and skeleton modeling for example) need to avoid it. Your assembly might be doing the actual engineering to make sure parts can work together, or maybe you’re just documenting the assembly so it can be assembled. It’s ok to have different assembly files for different purposes. Efficiency is one frequent goal.
This is a chapter from Mastering Solidworks, 34 pages of pdf glory.
This chapter introduces you to techniques you can use to manage performance issues as well as
general-use issues, efficiency, browse-worthiness, and searchability in assemblies.
◆ Set apart the elements of an assembly
◆ Increase performance by using SpeedPaks
◆ Organize assemblies by using subassemblies
◆ Group parts and mates by using folders
◆ Show names and descriptions with Tree Display options
◆ Employ helpful assembly tools
https://cadforum.net/app.php/downloadsystemdownload?id=14
I’ve learnt this the hard way with my biggest assembly yet (around 600 parts, in context). I thought it would make sense to do a single assembly since every parts are welded together. To fix my horrible performances, i tried to create new sub-assemblies. Sadly parts that had refereces in other subassemblies now loose the referece.
In each sub assemblies there are only 4 parts that are no longer referenced, but those 4 parts are used by hundreds of parts present in the subassemblies.
Is there an efficient way to redo all the references?
I click on the link and get this?
It’s logging you out. Try signing in, or from your current page click Quick Links>Downloads.
Better yet, matt can you allow guests to download files? This would nullify the logging out problem…
GOT it
OK now
Login again & all is well
Thanks
That plugin gives me headaches. The permissions are a mess. I’ll have a look.
matt,
Just be sure to keep us updated where it is in the process:
Parking lot? They really tell people that? Maybe they should add Field of Dreams.
SOLIDWORKS ER? Emergency Room? Is there triage? Maybe a morgue?
And Mature? Audiences 21 and older?
Ok, I think I found it. Can you hear me now?
Yeah, hilarious right? They ruled my idea to donate to this forum “Out” because it violated there Terms of Service. I think you’ll find the exchange entertaining, because it technically didn’t violate the TOS…They still haven’t fixed it and I don’t expect they will, but it’s still up for now:
https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/#community:yUw32GbYTEqKdgY7-jbZPg/idea:NT1onypbQPKS0-pNyYC0Uw/comment:swym%3Aprd%3AR1132100503382%3Aidea%3ANT1onypbQPKS0-pNyYC0Uw%3Acomment%3AbeLRf6KfQxWagalBDtnAlw
At one point I posted this when the colors aligned with it:
They made some changes. I have no idea if that chart had any impact.
