It seems that I cannot run this snippet within my PDM TASK macro even with “PDMWorks Enterprise 2023 Type Library” enabled in the VBA references in Solidworks, but it works correctly when debugged with Debug.Asserts False uncommented.
This task script is a patchwork and some parts related to pdm are already written as late binding, while the snipped below is derived from some code written as early binding…
I am not sure this is the problem, but if I comment the snippet the pdm task runs without crashing, so the problem is likely there.
I would like to convert this snippet from early binding to late binding, and try to run in our pdm sandbox again.
anyone could help me?
Sub GetLocalCopies(vFilePaths As Variant)
Dim pdmBatchGetUtil As EdmLib.IEdmBatchGet
Set pdmBatchGetUtil = Vault.CreateUtility(EdmUtil_BatchGet)
Dim pdmSelItems() As EdmLib.EdmSelItem
ReDim pdmSelItems(UBound(vFilePaths))
Dim filePath As String
filePath = vFilePaths(0)
Dim pdmFile As EdmLib.IEdmFile5
Dim pdmFolder As EdmLib.IEdmFolder5
Set pdmFile = Vault.GetFileFromPath(filePath, pdmFolder)
pdmSelItems(0).mlDocID = pdmFile.ID
pdmSelItems(0).mlProjID = pdmFolder.ID
pdmBatchGetUtil.AddSelection Vault, pdmSelItems
pdmBatchGetUtil.CreateTree 0, 32
pdmBatchGetUtil.GetFiles 0
