I understand that there are a lot of parameters and metadata inside the native files, but view generation alone is taking too much time.
I am working on performance, to improve our workflows and to fix problematic data. Here is what I found. I made some tools with API to analyze drawings and apply settings in batches to all views, but there is something I do not understand yet.
An enclosure made with sheetmetals panels (not sheet metal features, only extrusions, cuts, holes, patterns, splits)
the first time I opened the mutibody model it rebuilt in 9 seconds. Now I make it rebuild in 3.5 seconds with the same amount of geometry and the same amount of features tweaking the way it was modeled.
(I am writing a separate post on the matter)
Nevertheless its 2d drawing is slow and SW hangs a lot.
E.g. If I try to hide some body (to clean up a view background) in the view property and I press apply it takes MINUTES to update with SW not responding.
There are a lot of holes, i tried to disable the annotation visuals and put the threads in draft quality.
no luck
I disabled di overlappIng edges high quality setting in the drawing document properties.
no luck
I exported the 3D data as parasolid, reimported in SW and I used the same 2D drawing relinked to the new 3D.
result: as expected the dimensions blown up, but the view generation and body hiding is an order of magnitude FASTER.
I suspected hole wizard as a culprit, and I am replacing the holes with cuts, but it does not seem to be the only cause.
my intuition is that SW is bringing a lot of overhead inside the drawing views, overhead not present with a dummy solid exported from the very same geometry that caused a slow drawing.
This overhead is apparently affecting view generation for whatever reason.
I want to understand that reason.
The amount of edges, view styles etc for native SW data based drawing and imported parasolid model are exactly the same.
Alin any idea you could share?
I cannot share data without an NDA.
