Disable all Crosshatches in drawing section view
I have been trying to disable the section hatching for every component in a section view.
Disabling the material hatching and setting the area fill to none.
Looping every single face in the view seems to take forever to process a single face…is there a better way to achieve this?
Sample code from the help I modified just select a section in a assembly and start the macro.
' Preconditions:
' 1. Open public_documents\introsw\bolt-assembly.slddrw.
' 2. Select Section View A-A in the FeatureManager design tree.
' 3. Open the Immediate window.
' Postconditions:
' 1. Gets face hatch data.
' 2. Examine the Immediate window.
Option Explicit
    Dim swView As SldWorks.View
    Dim vFaceHatch As Variant
    Dim swFaceHatch As SldWorks.FaceHatch
    Dim swFace As SldWorks.Face2
    Dim i As Long
    Dim temp As Boolean
    Set swApp = CreateObject("SldWorks.Application")
    Set swModel = swApp.ActiveDoc
    Set swView = swSelMgr.GetSelectedObject6(1, -1)
    Debug.Print "View   = " & swView.Name
    Debug.Print "  Type = " & swView.Type
    vFaceHatch = swView.GetFaceHatches
    If IsEmpty(vFaceHatch) Then
        Debug.Print "  No face hatches in selected view."
        Exit Sub
    Debug.Print "  Number of face hatches in this view = " & (UBound(vFaceHatch) + 1)
    If Not IsEmpty(vFaceHatch) Then
        Debug.Print "  Face hatches ="
        Debug.Print ""
        For i = 0 To UBound(vFaceHatch)
            Set swFaceHatch = vFaceHatch(i)
            ' Get face hatch data
               Debug.Print "Current Material crosshatch = " & swFaceHatch.UseMaterialHatch
               Set swFace = swFaceHatch.Face
               swFace.Select2 True, 0
               swFaceHatch.UseMaterialHatch = False
               swFaceHatch.HatchType = 1
        Next i
The hatching triggers a view update if automatic view update is ON
disabling view autoupdate until the loop finish greatly speed up the process,
Less than 10 seconds seconds to process 250 faces
Dim swDrawing As SldWorks.DrawingDoc
Set swDrawing = swModel
swDrawing.AutomaticViewUpdate = False
