Two separate flat surfaces are joint together. Joint between connections is tangent to each faces. However, according to Deviation Analysis joint at the extreme right end (green arrow shows) is 0.04 degree. What is the reason?
I assume this also should be blue arrow as well.
XXXPart7.SLDPRT (71.9 KB)
