Creating a highly reflective image rendering using SW2024 Appearances
I have a titanium component. The material chosen is material is Ti-6Al-4VSolution treated and aged (SS) I want the component to have similar image properties as a highly reflective chrome bumper as found on cars. I am not getting reflective surfaces when I change the advanced settings in the chromium plate appearance. the image graphics on the select appearance window shows the surface I would like, but when attached to my part is returns a dull gray looking appearance. I have a Alienwar3 m15 R7 compouter with NVIDIA GeForce RTX 3080 Laptop GPU/PCle/SSE2 graphics card. It appears my graphic card may not support RealView graphics. Can anyone confirm if this is the case or can anybody suggest a work around? I would want to save those appearance settings, so I can apply to the next part component.
if you want true reflections you have to use Visualize, or Twinmotion or some other external Render tool Your RTX 3080 isn’t the problem the SolidWorks RealView mode is poor at best. I never use it anymore just slows down the SolidWorks tool. Rendered in Visualize tool.
