Creat a Macro to Add colors to each feature in a a part
Hi All I 'm not sure where to look on how to Add a unique color to each Feature in a part, the reason is that when i export the part to Unreal it would then allow me to assign Unreal texture a lot more easier, This would also be useful with surfaces on the part. It has been a while since i made some macros and i know there is a API list of all the functions for parts etc.
I usually export the part as a step file, then import into Unreal using the Data Smith tool inside Unreal.
In the past i manually colored the parts in SolidWorks. In this macro I would automate this for each feature in the part and assign it a unique color.
Thanks for your input.
Hi Craig Makarowski, See code below.
Option Explicit
    Dim swDoc As SldWorks.ModelDoc2
    Dim R() As Double, G() As Double, B() As Double
    Dim vMatVal(8) As Double
    Dim i As Long: i = -1
    Set swDoc = swApp.ActiveDoc
    If swDoc Is Nothing Then End
    If swDoc.GetType <> swDocPART Then End
    Set swFeat = swDoc.FirstFeature
    While Not swFeat Is Nothing
        If swFeat.GetFaceCount <> 0 Then
            i = i + 1
            ReDim Preserve R(i)
            ReDim Preserve G(i)
            ReDim Preserve B(i)
            GenUniqueColor R, G, B
            vMatVal(0) = R(i)    ' R
            vMatVal(1) = G(i)    ' G
            vMatVal(2) = B(i)    ' B
            vMatVal(3) = 1       ' Ambient
            vMatVal(4) = 1       ' Diffuse
            vMatVal(5) = 0.5     ' Specular
            vMatVal(6) = 0.3125  'Shininess
            vMatVal(7) = 0       'Transparency
            vMatVal(8) = 0        'Emission
            swFeat.SetMaterialPropertyValues2 vMatVal, swInConfigurationOpts_e.swAllConfiguration, Nothing
        Set swFeat = swFeat.GetNextFeature()
    Wend
    'swDoc.GraphicsRedraw2
Function GenUniqueColor(ByRef arrR() As Double, ByRef arrG() As Double, ByRef arrB() As Double)
reset:
    Dim R As Double, G As Double, B As Double
    R = Rnd: G = Rnd: B = Rnd
    Dim i As Integer
    For i = LBound(arrR) To UBound(arrR)
        If Int(arrR(i) * 254) = Int(R * 254) Then
            If Int(arrG(i) * 254) = Int(G * 254) Then
                If Int(arrB(i) * 254) = Int(B * 254) Then
                    GoTo reset
    Next i
    arrR(UBound(arrR)) = R
    arrG(UBound(arrG)) = G
    arrB(UBound(arrB)) = B
End Function
Thank you very much that works excellent!!
Thank you very much :slight_smile:
[/quote]
Hi Craig, the code below will give a unique color to each component in a assembly. Thought I’d drop it here since you asked about it in our PMs.
' # Title: Random Colorize Components               #
' # Version: 24.1.26                                #
' # Author: Stefan Sterk                            #
Option Explicit
    Dim swAsm As SldWorks.AssemblyDoc
    Dim swCmpDoc As SldWorks.ModelDoc2
    Dim Components() As SldWorks.Component2
    Dim Component As Variant
    If swDoc.GetType <> swDocASSEMBLY Then End
    Set swAsm = swDoc
    If swAsm.ResolveAllLightWeightComponents(True) <> 0 Then End
    ' Initilize color array
    ReDim Preserve R(0)
    ReDim Preserve G(0)
    ReDim Preserve B(0)
    Components() = swAsm.GetComponents(False)
    For Each Component In Components
        Set swCmpDoc = Component.GetModelDoc2
        If swCmpDoc.GetType <> swDocASSEMBLY Then ColorComp Component
    Next Component
Function ColorComp(vComp As Variant)
    Set swComp = vComp
    Dim Index As Long
    If UBound(R) <> 0 Then
        Index = UBound(R) + 1
        ReDim Preserve R(Index)
        ReDim Preserve G(Index)
        ReDim Preserve B(Index)
    vMatVal(0) = R(Index)    ' R
    vMatVal(1) = G(Index)    ' G
    vMatVal(2) = B(Index)    ' B
    swComp.SetMaterialPropertyValues2 vMatVal, swInConfigurationOpts_e.swAllConfiguration, Nothing
End Function
reset:
    Dim i As Integer
                    GoTo reset
    Next i
End Function
[quote=“Stefan_Sterk, post:5, topic:2769”]
Option Explicit
    Set swAsm = swDoc
    ReDim Preserve R(0)
    ReDim Preserve G(0)
    ReDim Preserve B(0)
    Next Component
    Set swComp = vComp
    Dim Index As Long
End Function
reset:
    Dim i As Integer
                    GoTo reset
    Next i
End Function
[/quote]Fabulous Stefan :smiley: :100: :+1:
