Gang-
I was hoping to get an update on convergent modeling in Solid Edge. As I recall convergent modeling required a Reverse Engineering add-in. Now that was way back in Solid Edge ST10. I was wondering if anyone is actually using convergent modeling. I found the SE functional matrix and it shows that convergent modeling is available at all SE levels. But the reverse engineering capabilities are in the Classic and Premium.
So what is the difference between CM and Reverse Engineering?
Ryan, the Reverse Engineering tools are aimed at taking a mesh model and converting it to a BREP model. Convergent Modeling allows you to keep the imported mesh model “as is” and add/subtract BREP features on the mesh body, thus creating a hybrid mesh/BREP body.
It would have to be exported as a mesh (STL). Primary use case would be for additive manufacturing output. This also allows you to use Generative Design output, which is a mesh, and then add precise BREP geometry to it.
If you want BREP as an output, then you need to use the RE tools to convert the mesh to BREP.
