zwei
May 12, 2021, 11:06am
1
Just curious, when it comes to API/macro/code, what do you prefer when you insert your code as answer/question in the forum?
Personally, I prefer to use quote just because i can do some text formatting to indicate some area that need to be change
'Lorem Ipsum
'Lorem Ipsum
'Lorem Ipsum
Code function has a select all option but cant apply any formatting
'Lorem Ipsum
[color=#FF0000]'Lorem Ipsum[/color]
'Lorem Ipsum
I rarely use upload unless it is a macro that i want to share as a whole.
We need a proper syntax highlighter such as: phpBB • [ABD] Prism JS syntax highlighter ⚡️ . I’ll request it in the Suggestions area.
matt
May 13, 2021, 2:11pm
3
Ok, this is added, but I’m gonna rely on you guys to tell me if it’s working or not. Here’s a screen shot of the settings. Looks like they use some named themes. JSculley if you have experience with this, do you want to suggest a theme to use?
Solarized. It’s pretty popular. I use it everywhere I can. Let’s give it a whirl:
public static void main(String[] args) {
System.out.println("Hello World!");
int Main()
Console.WriteLine("Hello World!");
The highlighting works well. It also gives you a ‘Copy’ button and a hint at what the language is. Nice.
matt
May 13, 2021, 3:42pm
5
Ok, I changed the theme to solarizedlight.
