Cad in the cloud
I can agree with that, I think I can understand where you’re coming from.
I can’t see a way around explicit constraints in many of our key components. Some of our models literally could not be have designed without construction sketches or an alternative form of explicit constraints. (unless we were to do it through trial and error) I don’t care how advanced implied constraints are. They won’t know that “the tip of this wedge shaped extrusion needs to be exactly located tangent to a nested pattern of 66.3mm diameter cylinders as they move tangent to a plane at a 12 degree angle.”
We don’t allow external references in production, but we DO use explicate constraints as some of our most important design tools. (this usually means sketches with construction geometry in feature sketches or dummy sketches, but it can also mean nonproduction “design assemblies” that allow external references for the purpose of generating calculated production parts.
just thinking back to my school days, 4 bar and other “bar linkages” are another example where some kind of explicit “calculator” is an absolute requirement for a meaningful design. complex mechanisms become unintuitive rather quickly. possibly you could design a four bar linkage without explicit references, but you would certainly need to build a separate linear algebra “calculator” to determine the exact link lengths and ground locations based on the equations that drive the precise lengths. (basically reinventing the wheel of what a parametric solver gives us)
Explicit geometric references allow engineers that don’t remember a day of linear algebra to built pretty complex “math-based” models without even cracking a linear algebra text book. That is nothing to look down at or “overestimate”
Again I don’t doubt that this type of work can be done in SE using other non solidworky forms graphical explicit constraints, and I do believe there is a time and a place for “implied constraints” but I do doubt that our SW models will be nearly as valuable to us as they are now if we were to migrate especially some of our key components.
I am a skeptic of the benefits of the new fancy way of doing things. But I’ve never used it even once. And people I respect tell me it is a game changer, so my mind is open.
Maybe in another year or so I will make the jump to SE. If I do, it won’t be because of ST, but I will certainly do my best to take advantage of it.
(matt should this be broken out as it’s own topic?)
Yeah, I can see that. At one point you had to solve this problem in SW. I’d be willing to bet that it could be solved elsewhere.
Yes this. The cost of a migration will vastly dwarf the cost of anything else for us. A pdm migration was a bad enough multi year project. A true cad migration? I will be the most hated, unfire-able person in this company if that happens.
nordstjernen740 Above, I’m talking on plain migration of SW data to SE, not using the purpose built SW to SE Migration Tool. Using SE Sync natively you can build explicit constraints, or as others said work in a hybrid or traditional Ordered mode to do the same. The beauty of Sync is that explicit constraints can be added at any time, so for imported geometry you can actually rebuild those things that are missing fairly quickly. Skeleton sketches may be a sticking point because the sketches do not come across.
For the most fidelity when you migrate to Solid Edge, use the SolidWorks Migration Wizard. It requires you maintain a SolidWorks license while using it (it works with the SolidWorks API), but it will provide a little more automatic feature recognition of Sync features plus it will provide assemblies with mates, virtual components, and configurations (as SE Alternate Assemblies), and drawings with intelligent drawing views that are associative to the 3D model.
Thanks Kenny, Maybe I haven’t been clear, but my focus in my replies has always been migration and how much loss of data/value would occur would we choose to do so. not a from scratch se vs sw. I have no doubt that complex constraint specific designs can be produced in solid edge from scratch, but can I reuse old, but still valuable, imported solidworks components to do so? Or will all of our intelligently designed components that actually do rely on sketches and constraints for their definition and ability to be customized to match specific use cases need to be remodeled with new, “Rethought” constraints in SE?
A solidworks migration wizard sounds way more promising than anything we are hearing out of the 3dx world. In practice how does this play out?
Is this something that SE customers do in batch? or on demand? Intern audit work?
Still no sketches even with the “solidworks migration wizard”?
[mention]nordstjernen740[/mention] You were clear on your intention to fully migrate. I was just trying to be clear that it was possible in Synch when creating from new or after the fact (native or translated) that you have the ability to create explicit constraints since it seems to be a common misconception that they cannot be created in Sync.
Per the topic of the SW Migration Wizard, I have not used it personally, but from what I’ve seen the migration process for parts is roughly the same as just opening them directly with SE with the exception of automatic Hole recognition. There may be more, but that’s what I have been able to gather. You still get a Sync body but I don’t believe you get any sketches. Migration can be done in large batches or smaller on demand batches, choice depends on need. Video link below:
https://www.youtube.com/watch?v=IHq90qBGQpM
This has been helpful.
So currently a migration to SE would mean throwing out our sketches, basically as a trade off for some intuitive direct editing.
It is good to know what we are up against when weighing how bad sw needs to get before we consider becoming a multi cad company.
As a side note.
Do sketches as we know them in SW exist at all in the from scratch solid edge world? If you are in “history” mode for example?
Of course sketches still exist. In Ordered they would work identically, and in Sync they are free from historical order so they can reference each other (awesome when making a network of guide curves for a surface) and can be used in both Sync or Ordered features. If used for a Sync feature, they get moved to a Used Sketch folder, but can be restored if still needed.
Ok i figured they must. Does anyone in the SE world have hope that the SW to SE translation wizard will be even more complete and include sketches in the coming years? Or has it been relatively stable feature wise of late?
mike miller recently went through this. Maybe he can add some extra information.
That would be present tense, not past. :slight_smile: :open_mouth:
Anyhow, currently there is no way to get sketches from SWX and use them for driving geometry in SE, AFAIK. It’s basically a Parasolid wash for the geometry, with some automation for adding custom properties, material, SWX features as select sets (groups), associated drawing views, and links between files. Maybe someday Siemens will figure out how to convert SWX files feature <> feature, then you could choose to move feature to Synch as desired. Hey, they’re already doing this for SWX drawings. Probably more chance of this than a reliable SWX >> 3DX translator.
The other thing to keep an eye on is CADdirect (new in SE2022). It allows you to add a non-native part to an SE assembly and maintain the link. Currently it only supports NX files, but Dan Staples said SWX functionality will be here soon. You could migrate all your sheet metal and prismatic parts and keep using SWX for the cams and other highly parametric parts, then gradually phase it out.
Is it me, or does CADdirect seem like Siemens feels that SWX is heading towards its own demise and is making sure that SE is the main choice for replacement. I’ve always felt that the main (and even minor) players in 3D space are all broadly the same (different sets of pros and cons and workflows). So, the key to make a choice would be cost, support and ease of migration. CADDirect seems like a major swing at reducing the pain from migrating.
This ability to read other CAD system’s sketch and feature data has been talked about as long as I have been aware of CAD. Isn’t 3D Interconnect Solidworks’ tool to use SE (and others) files in SW assemblies? Thing is they all want to keep you trapped in their system so as soon as SE for example figures out how to read the proprietary data in the file SW is going to change something to break it. The whole point is to keep a moving target. Maybe I’m dead wrong but I doubt this will ever happen, heck DSS is moving the opposite direction by putting ALL your data in their cloud. Not only do they not want it to work with other systems, they don’t want you to be able to get it to other systems.
We thought we would be able to use some 3D interconnect functionality. Turns out a short while in that all the demos of SW2019 doing magic with SE files were using older version of SE. 3D Interconnect would just error out on every one of our 2019 SE models. We learned, not quick enough, that every instal of SW needs to have Enable 3D Interconnect unchecked in Import settings. Heck, eDrawings cannot view the 2019 SE models so the Preview Tab in PDM is almost never used because we get an error dialog (just click OK training) every time a SE file is selected, if it would just show an error message in the view area that would be nice. The number of users that had “Vault is locked up” because that tiny dialog got buried and was blocking the Vault View… Took me a bit to figure that out, Good times. We had to do reg edits to disable the drawing previewer in PDM because it was causing serious performance issues in SW; took tech support months to get to the bottom of that. Fortunately, they did and were quick to provide us an easy reg edit solution.
My point, I’d be very surprised if any of them ever invest the effort to read the feature data of other systems, mostly because they are making sure that others cannot read theirs.
Wow thanks for the info on the can of worms something like this would do on the pdm side. Seems like there is a lot of value to just being a single cad company and using pdm for just solidworks files. Side note: Edrawings is a joke and I can’t believe we’ve managed to make it a few years without major issues. probably our vanilla solidworks data helps. 2021 was a downgrade for edrawings.
3d interconnect in my opinion is nothing more than a fancy one click translate/“untranslate and open with” on the fly. With maybe some native layering of metadata and native feature additions spread on top. I would assume that CADdirect is a clone of this. Potentially useful, but only if you have both programs on the same machine (and its not buggy).
3d interconnect also caused problems for us and we have never had multiple cad software. Just having it on and having downloaded files automatically come in with it turned on caused problems in pdm.
Maybe I am optimistic, but I feel like if Siemens can crack the nut of keeping drawings linked to models after a translate, maybe they have a shot at a parametric translation that includes sketches? I can see them being a year or several years behind latest SW data, but owning the kernel has got to be an advantage for them. Then again Dassault should have an advantage on the SW to 3dx front since they own and develop both software. lol. I just don’t know if I believe that they are even working on it.
Didn’t I learn at SWW several years back that 2d sketches are actual run on an entirely different kernel than parasolid? d-cubed? this must mean that solidworks basically built an interface between the two “languages”
This has already happened. Several years ago. I’ll find more detail for you.
Parasolid is 3d solids and surfaces. dcubed is sketch solver. Both owned by Siemens. https://www.plm.automation.siemens.com/global/en/products/plm-components/d-cubed.html
I tried to state a couple times that I can be wrong. Please don’t make any big assumption or actions based on my comments alone. I don’t want others to go through the same pitfalls I did/do. On the flip side, it’s just my perception of what happened and there’s a whole lot that I don’t know or just miss, so my perception is likely off some portion of the time. If someone finds some truth that I obviously missed I’m grateful to be enlightened and fix my perspective. Although it might take me a little while to chew on it first.
As far as I know the 3D Interconnect would have been fine if we would have stayed on ST9 instead of going to 2019 (ST11).
eDrawings should be called eModels, it does much better with models. People here don’t trust it to show drawings accurately. We use the automatic rev table (via PDM) and the table is almost always a mess in eDrawings. After spending way too many hours chasing geese and rabbits with support case we just moved on.
I wonder how many Solid Edge users still use PrintDFT.exe. Any Edgers out there using it? So Solid Edge has the best drawing view ever IMO. The zoom pan function sucks, but it opens drawings faster than any pdf. It’s a viewer that draws the embedded EMF from the .dft file that is generated on each file save. The EMF is a vector format, not raster image, so the lines scale and such. The best thing for us was the viewer was 100% guaranteed to display the drawing exactly as it was last saved, every time, always, no references needed. We miss that so badly. If Solidworks would just embed an EMF in a similar manner and give us an .ocx or API call to extract it we would use that for drawings. I digress.
[quote=matt post_id=17963 time=1645717820 user_id=49]
[/quote]
Here is a nice video that shows this link and the associativity in the converted drawing.
https://www.youtube.com/watch?v=qLSZE2lryYo
We’ve chased all the same rabbits. PDM was sold to us based on the “Party trick” that edrawings drawings including title blocks automatically update on state changes without opening in solidworks. What a nightmare it was to get working. If you want to know all the rules that need to be in place for this to work correctly I’m your guy. It really is a rabbit hole. We actually do have it working though. Our 3rd party manufacturers use edrawings to read our 2d sw prints without any neutral files.
