So I have a part that was downloaded from McMaster Carr. It has one configuration. No matter what I do it will not seem to display the file name in the BOM.
If I go into the configuration properties and set it to “Configuration name” it shows that. If I set it to “User defined” it shows that. If I change it to “Document name” it doesn’t change and just shows whatever it was set to last.
I’ve never seen this so any ideas what the problem is? I’m unaware of any other setting that could cause this.
Thank You,
Edit to Add: This really doesn’t tell me what happened and maybe it was just a SW glitch, but I did a “Save as” replacing the part in the assembly and it fixed the issue.
What was the created date of the Top Plane? If a part template was really old, it can cause loss-of-function problems like that. Opposite of gain-of-function… For example, if that option was not available in the template version (often 1999 for McMaster <()> ) it may not be available now.
Check the part properties and see if there is anything in “Configuration Specific.” That seems to override the “Custom” tab. I’ve found SW will fill in the Configuration Specific table when I do a “Save As” on a part.
That’s one of the first things I looked at when changing the config stuff didn’t work. I didn’t see anything there but I could have certainly missed it.
