Hello everyone,
I’ve been trying to balloon some dimensions for our inspection sheets, and I would like them to be red. The way I find easiest to do this is to make one red and then paint the format to all the other balloons. However, when I try paint the format to a balloon within the square of a drawing view, the color does not change. The strange part is I go into the line color settings for the individual balloons and the non-red ones show their color as red. Is there something i’m missing? If there’s an easier solution or an easier way to color all these some input would be much appreciated.
Thank you!
Have you tried CTRL+R or CTRL+Q afterwards? Sounds like something that’s been 95% implemented. Try modifying anything inside it to see if it changes color, like add a REF. to the dimension or something
I’ve never done something like this but the way you proceed would be the way that I would proceed also. You could perhaps make a note style? Maybe that could do the trick?
I’d suggest using Layers. Set up a Layer that’s red, apply it to one dimension, and save it as a Style (as AlexLachance suggested. That will (or at least should) allow you to apply this Style to new or existing dimensions.
I appreciate the replies and will look into setting up layers and a style for this. My solution now is to place all the balloons outside of drawing views, paint the format for the color, and then move them into place after the fact. This is so far my only work around i’ve had work, so it must be interacting with the drawing views weirdly.
It is also what I believe he was refering to at first, but his latest reply saying that he places balloons outside of drawing views, paints them and then move them in place makes me think that he’s doing another methodology, maybe even drawing his own ‘balloons’
hopefully this clears things up. The balloons in question come from the Balloon command under my Annotation tab. I think they’re used for BOM usually but we use them to help clear up which dimension is associated to which on the inspection sheet. They seem to act like a normal circular note but I believe it has more linkage to custom properties and when used with a BOM can pull all the balloons into that. I just use them like notes though.
Oh, you’re refering to part numbering balloons and not dimension balloons or revision balloons.
In that case, pre-created annotations or notestyles would be your best options. We use a somewhat similar thing to call out assembly configurations on certain cases.
Here’s an example, while it’s not a balloon it’s an underlined text attached to the balloons
I seem to remember that someone at the old forum posted a method for changing the color of text inserted into a dimension. I’m not sure, but I think it was josh. Maybe there’s some code to use to put a circle around just the added text and not the dimension? That would allow having all this in one annotation like you want.
It’s not text within the dimension, it’s a balloon created with information put into it and then set to a specific color. Saved Annotation/Notestyles will achieve what he wants
This is also a good trick for me. I should mention i’m still within my first few months of using solidworks, so standard features tend to blow my mind sometimes.
