Depending on the complexity of the design I will either start with a sheet-metal feature or solid modeling and then convert to sheet metal. The more complex (multiple compounded angles) the more likely I am to start off with solid modelling and then convert to sheet-metal at the appropriate point. I find it a whole lot easier in the design process for complex sheet metal work.
I use mirror in all aspects, sketch, features, bodies and final parts (lefts and rights). Never had too many issues with it.
My go to for assemblies is SSP method, and rarely use multi-body sheet metal parts (we do not weld much), more mechanical assembly type work. Mirrored and pattern parts is a definite yes.
I use hole wizard for all holes type. I believe it works just as well as it does on non sheet metal parts.
As for parts that have many bends, I guess it’s the same as any other parts (use of patterns…) and ensure manufacturability. I am not too sure what you mean be ‘flexed to fit BOM’.
