I was asked to make this part for a laser cutting demonstration. The result is close enough, but I got some trouble with the Wrap Feature. I want to be able to control the angle, the distance and radius of offsets more freely. One way I found is to make the Linear Pattern in one sketch, then create another sketch in the same plane and Convert Entities, then Offset+Wrap. But I get problems with the Select Chain and Offset when changing the Linear Pattern value; one way to solve this is making another sketch and converting everything again. LOL
I think using sketch is not the best approach for this, but I couldn’t make it with features…
How would you do it? Is there a way to make just one Wrap and Pattern it around?
I uploaded one file with the method I explained and another after changing the Linear Pattern value.
image.png Double Sketch2.SLDPRT (32.9 MB) Double Sketch.SLDPRT (24.8 MB)
So it’s Friday and I’m really unmotivated so I decided to play with this for a bit. What I came up with was/Is a bit sloppy but maybe something you can use.
instead of wrapping the entire thing I wrapped one instance. I placed a helix in a circle and extruded the tube from that sketch (Lots of ways to do this and what I did was probably one of the worst ways ). The sketch of the wrap/cut is calculated based on the information from the helix. Alter the OD, Pitch etc and the angle in the sketch changes to match.
I then did a curve pattern feature and based the instance spread on the sketch. I’m assuming that I was running into a ZTG issue if I used the exact measurement because the pattern failed, but by subtracting .0001 from the instance spread it seemed to work.
I messed with it a bit, changed pitches a couple times, and it rebuilt with the change…but I suspect at some point it’s will explode. Part1.SLDPRT (3.16 MB)
Edit To add: I didn’t do anything with the array count. But if you wanted it to have a certain number or cover a certain distance I’m sure you could calculate the number in the array with another equation and have the array count equal to that. For more radical changes it does explode. I have been able to fix most of it by changing the “-.0001” to a larger number.
