The VAR you bought the software from should give you access to the download for the latest version while you were on subscription, but I can’t promise you they will. I would recommend reaching out to them.
Thanks, Glenn. I’ll check with them.
yes, you should ask your reseller as Glenn suggests.
They can verify which versions/SP’s you have the right to use based on your license number. They have access to the download area with all service packs. If they help you now, you are more likely to buy more products from them…
