Thermal Testing including Solar Effects
A bit more of a general engineering question than CAD.
Does anyone have any experience devising a test plan for thermal testing of a product, but also factoring in solar loading from the product being sat out in direct sunlight?
We have a product that’s always been a bit marginal on reliability at high temperature, but now there is a desire to offer it painted in dark green and black, in addition to the desert tan colour it has historically been offered in.
Logic dictates that the darker colour will be more of a heat trap in sunny environments, but quantifying this and testing for it is something we need to check.
We have been testing products in direct sunlight, but what is the marginal reliability? Fading colours of the paint? Plastic parts deform or worse? Or is mechanic or electronic performance affected by temperature?
In the past I was in R&D of measuring equipment for gas, mechanical and electronic, often placed outside in the open, all over the world. Big difference if it is placed in north of Europe, compared to India as example.
Electronic performance, we have components already running at or above their temperature limit (85°C typically) while the product is in use if operating at high ambient temperatures (>45°C).
We have so far had no complaints about paint fade or plastic deformation.
I have found BS EN IEC 60068-2-5:2018 “Environmental testing - Tests. Test S. Simulated solar radiation at ground level and guidance for solar radiation testing and weathering” which seems to be what I’m after. Just trying to understand it, relate to our products then work out if we can test in house with our current gear, or do we need to find an external test house.
The colour of our electronic cabinets have been white, for this purpose. Haven a small roof to protect for direct sunlight can be mandatory in some regions of the world.
Having exceeding temperatures for components at ambient temperature of 45°C already, and changing to a more darker colour, will become a challenge.
Might need Peltier or absorption cooling system.
