march 2022 UPDATE
After upgrading to SW2021 I noticed that dimensioning an EXTERNAL thread using the INNER lines of the thread gives the correct dimension with M, G etc. based on the thread feature standard attached to the EXTERNAL lines.
If you pick a male thread EXTERNAL edges it results in a DIAMETER dimension, so be careful what you select.
–original post—
I have stumped in the SPR 680544 bug apparently:
Dimension of cosmetic thread in drawing is incorrect, shows diameter dimension not thread size (M)
Inactive (as expected)
EDiT:
Is there some workaround to avoid replacing the diameter symbol with M for threads for MALE metric threads?
It seems that solutions only refere to holes…
EDIT2:
it seems that is a sort of intentional behaviour, but according to our drawing standards we do not use annotation for ext thread dimensions.
our engineers are manually replacing the diameter symbol everytime they attach an external thread dimension on the side view of a shaft with G, M or whatever is required by the standard applied.
The alternative I found is to pick the bottom line of the thread and the dimension attached to the inner lines displays the value of external diameter instead…
