Since switching to SW2022 I’ve seen this coordinate system show up when I’d click on a component in an Assembly. I usually research new features, but didn’t this time, just assuming it wouldn’t be anything I’d want to use. I found it mildly annoying, but not enough to investigate and see if I could turn it off.
Today, I lost a washer in my Assembly. I clicked on it in the tree and that thing popped up. In my little brain I thought “I’ll click on the Z and drag, and see what happens.” Guess what? I was able to move it by doing that, and get it out where I could get to it.
If this is the “move with triad” triad, then it has nothing to do with instant 3d. It is the same as dragging the part, but using this allows it to only translate/rotate along the selected direction. It also allows for precise movements. (See GIF below)
Once I was inside the reply, I could no longer see who had pointed it out! LOL. I was too lazy to open a 2nd tab to the same discussion…and I didn’t edit it… Which I am fixing now… sigh
In my opinion It’s the most annoying feature in SW. I turned it off from the very first day I upgraded to 2022.
For those who asked, yes, it goes away if you turn off instant3D.
And if the component is fixed or fully defined by mate, you can not move the component using it. So it’s totally worthless (for me)
@Glenn Schroeder I’m sure you know that you can select the component in Feature Tree and isolate it. It’s what I do when I can’t find a part in the assembly.
I love the “Move With Triad” tool… Have had a keyboard shortcut for it for ages.
That said it would bug the crap out of me to have it show up every time I selected something. I also toggle off Instant3D, so good to hear that will toggle off automatic popup of the triad.
I use it for getting parts rotated into a close approximation of where I want a part before applying mates.
I only use the triad for moving the sectioning tool or a camera. It seems a little fussy to pick the right part of it, so it rotates instead of translates.
Yes, I did know that, but this new feature is simpler than Isolating the component, dragging it out, then exiting Isolate.
Using SW 30+ hours per week since 2009 I’d never used it before yesterday.
It’s one of those things I’ve learned to ignore if I don’t need it. I keep Instant 3D turned on all the time since it’s so handy for making quick edits. Single-click on a feature to show dimensions, single-click on them to edit, and it instantly rebuilds.
To orient Parts before applying a Mate I right-click and drag to rotate, and have done so ever since learning about it from Kelvin Lamport at the old forum many years ago.
