sheet metal Flat Pattern bounding box, how to add offset?
Just curious, how would you have done this in Solid Edge?
My understanding is your ERP is receiving the wrong area to consume from SolidWorks, because your nesting consumes more then the area that SolidWorks sends, it then throws off your ERP for estimations. You’ve also mentionned that there’s an issue lying in the fact that the nesting Software does a better job on certain parts then others. Is there something that can be done on the nesting software to adress this, or is this something that everyone everywhere faces and adresses in their own manner?
So, let’s try and schematize this whole thing together.
Area of nesting = Comes from Technical Department.
Nesting = Done by nesting department.
Estimation/data entry = Done by estimation department.
If there isn’t anything that can be done to adress this from the nesting Software, then that is when ultimately you would be the one having to come up with the solution. Can you identify when, or what causes the nesting software issues in it’s estimation and when it doesn’t? That will help determining the proper way to go from there.
