Set text format of revision table to default
I am trying to access some options of a revision table after it is placed already:
  • Revision Symbol & checkbox
  • Auto Update Zone Cells
  • set table to default font
I cannot figure out how to do it.
Regarding the default font I also found this thread about it but even when first getting the default font with GetUserPreferenceTextFormat it won’t change the format with
boolstatus = swtable.SetTextFormat(False, swTextFormat)
Any ideas?
Stefan Sterk , gupta9665
This is the only place I know off the top of my head to modify those values.
https://help.solidworks.com/2016/english/api/sldworksapi/SolidWorks.Interop.sldworks~SolidWorks.Interop.sldworks.ISheet~InsertRevisionTable2.html
That is only possible if you insert a table though.
I was thinking that I might have to read out the default values & change the feature/annotation/tableannotation to the read-out value.
But whatever I tried - it did not seem to work.
Yeah, I guess I should have been a bit more descriptive. I don’t know of any way other than when inserting a new table to do this. I’ve looked through quite a bit of the documentation and it’s less than helpful.
This is i.e. how I set the line weights/layer for the BOM table:
'            Get & set table layer to standard for tables
            BOMfeat.FollowAssemblyOrder2 = True
            bomSetting = swModelDocExt.GetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingBillOfMaterial)
            swAnn.Layer = bomSetting
'            get & set standard table lineweight
            cfgInteger = swModelDocExt.GetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDetailingBillOfMaterialBorderLineWeight, swUserPreferenceOption_e.swDetailingNoOptionSpecified)
            TableAnn.BorderLineWeight = cfgInteger
            cfgInteger = swModelDocExt.GetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDetailingBillOfMaterialGridLineWeight, swUserPreferenceOption_e.swDetailingNoOptionSpecified)
            TableAnn.GridLineWeight = cfgInteger
The checkbox to follow the assembly order is accessed through the feature
* ```text
The layer is accessed through the annotation
The line weights are accessed through the table annotation
It's a super confusing system...
