We currently have a PDM task that creates PDF files in a network location (not inside PDM vault). When the PDM task is run, the PDF files are saved with a revision letter in the file name (for example: 514447_C.pdf). In the folder that the new PDF file is saved, there may be an old revision of the file (for example: 514447_B.pdf).
Does anyone know of a way to remove the old version of the PDF from the network location automatically? I am hoping that this can be accomplished with the PDM task (or action in the PDM transition).
One option may be to use a .cmd file that deletes the file from argument list. Then run that as a transition action.
Problem I can think of is getting the file name of the pdf to delete, I think you would need to do some string manipulation in the cmd file to get the pdf name for previous revision.
Are you using the Solidworks Task Add-in or some other PDF task?
