Open Drawing From BOM
Well Hello,
For those who wanna open a drawing directly from another drawing BOM. Stop searching for a solution because this post will give you on. Happy reading, wachting and opening drawings.
Note: The drawings needs to be in the same folder and having the same filename as the part/assembly you want to open from BOM.
Example
Here is a example how it looks like.
VBA CODE
' # Title: Open Drawing From BOM                    #
' # Version: 21.9.6                                 #
' # Author: Stefan Sterk                            #
' # Company: Idee Techniek Engineering B.V.         #
' # This macro will try to open the drawing for the #
' # selected component(s) in the Bill of Meterials. #
' # NOTE: Drawing file must be in same folder as    #
' # component and must have the same filename       #
Option Explicit
    Dim swModel  As SldWorks.ModelDoc2
    Dim swTblAnn As SldWorks.TableAnnotation
    Dim swBOMTbl As SldWorks.BomTableAnnotation
    Dim swComp   As SldWorks.Component2
    Dim i As Integer, selType  As Integer
    Dim frtRow As Long, lstRow As Long
    Dim frtCol As Long, lstCol As Long
    Dim Row As Integer
    Dim vComps   As Variant
    Dim CfgName  As String
    Set swModel = swApp.ActiveDoc
    If swModel Is Nothing Then Exit Sub
    If Not swModel.GetType = swDocDRAWING Then Exit Sub
    For i = 1 To swSelMgr.GetSelectedObjectCount2(-1)
        selType = swSelMgr.GetSelectedObjectType3(i, -1)
        If selType <> 98 Then
            MsgBox "Please select a cel from BOM!"
            Exit Sub
        Set swTblAnn = swSelMgr.GetSelectedObject6(i, -1)
        Set swBOMTbl = swTblAnn
        swTblAnn.GetCellRange frtRow, lstRow, frtCol, lstCol
        For Row = frtRow To lstRow
            CfgName = swBOMTbl.BomFeature.GetConfigurations(True, True)(0)
            vComps = swBOMTbl.GetComponents2(Row, CfgName)
            If Not IsEmpty(vComps) Then
                Set swComp = swBOMTbl.GetComponents2(Row, CfgName)(0)
                openComponentDrawing swComp
        Next Row
    Next i
Private Function openComponentDrawing(swComp As Component2)
    Dim compPath As String
    compPath = swComp.GetPathName
    Dim drwPath As String
    drwPath = Left(compPath, InStrRev(compPath, ".") - 1) & ".slddrw"
    ' Try Open Drawing
    Dim swDrw As SldWorks.DrawingDoc
    Dim errors As Long, warnings As Long
    Set swDrw = swApp.OpenDoc6(drwPath, swDocDRAWING, 0, "", errors, warnings)
    If errors <> 0 Then
        If errors = 2 Then
            Dim partNumber As String
            partNumber = Right(drwPath, Len(drwPath) - InStrRev(drwPath, "\"))
            partNumber = Left(partNumber, InStrRev(partNumber, ".") - 1)
            MsgBox "Couldn't find drawing for following part number: " & partNumber
    Else
        swApp.ActivateDoc3 drwPath, False, 0, errors
End Function
OpenDrawingFromBom.zip (13.1 KB)
Hi Stefan
Nice work!
Eddy
Hi Stephan,
I’ve followed the instructions in your video, but nothing happens when I use the mouse gesture; no feedback of any sort. The drawings are in the same directory as the models and the filenames are identical.
Any suggestions?
Hi Uncle,
I tested it and it works fine here.
Can you run the macro without using a gesture?
Menu Tools > Macro > Run and select the OpenDrawingFromBom.swp file
Thanks Stefan, I’ve downloaded the macro and shared it with my coworkers. All of them agreed that it was a macro that they did not know they wanted!
Edit: Hrm doesn’t seem to work on my side either, most likely because I don’t use gestures I’m guessing?
Hrm… Even with mouse gestures it’s not working… Wish this guy would come back and tell us what’s up
AlexLachance,
Looking at it, it doesn’t seem it would be too difficult to troubleshoot this macro. Have you tried editing it and opening the Immediate window, then running it to see if there are any errors output?
you have to select a BOM cell first (not in a header) using LMB
then you press RMB and drag to the left.
That should do it.
If nothing happens, then follow my previous question/advice to run the macro directly…
I haven’t tried yet because I have a few jobs to do this morning but might give it a shot this afternoon. It’s not doing anything at all though, not even sending one of the error messages that it should. I am selecting a cell, I tried selecting a row also, selecting the cell with the number.
I also tried using it directly from the bar, with mouse movements, and as a keyboard shortcut. None worked.
are you able to use macro recording and run that macro?
If so you can copy paste the code in there to test your environment.
Are you saving the macro in a directory that has no restrictions on user level? You can try using C:\temp in that case.
Nope. Nothing happens.
I have admin rights on the directory where the macros are stored.
Is it possible that the drawing you want to open is already open?
The code just opens it if it is not already, it doesn’t activate it to show on top of other windows if it was already there.
could you “Tile Horizontally” and show a print screen here?
Hi Eddy,
The drawing is not open.
I don’t know what a screen print would show you, so I recorded a video, but cannot find a way to attach it.
Matt, is it possible to attach my upload here?
Like Eddy Alleman the macro doesn’t activated the drawing if it’s already open. I updated the code in this topic which fixes this issue.
But this doesn’t seems to be the issue for you guys.
Are you guys opening the drawing in detailing mode?
For me the macro also doesn’t work when I have a drawing opened in detailing mode, Lightweight and Resolved are working fine for me.
Hey Stefan!
I am using Resolved, but my SolidWorks is in french rather then english. Could that be the cause?
This is the error I get on Visual Basic. 2nd image to show how I selected. 3rd image to show file location.
Hi Alex,
Can you check your references:
Menu tools > References
Eddy
language shouldn’t be the issue.
That error you get should be a easy fix. I made the macro (.swp) file with SolidWorks 2021 and you’re prob using a lower version of SolidWorks. Check out the following link which will guide you to fix this error; https://www.codestack.net/solidworks-api/troubleshooting/macros/missing-solidworks-type-library-references/
Hrm, it was as simple as fixing these references and now it works!
Thanks Stefan, wonderful work!
Hi Alex,
TIP: Sometimes it’s easier to create a new macro with macro recorder and then copy paste the code in there.
Those references will be ok already then.
Eddy
Hey Eddy,
I’m not too familiar with Visual Basic, I actually had to find where to click to open the References window once I pressed OK to remove the missing ones :laughing:
Nonetheless, I got it! Thanks for the advice, I will try to think of it next time if it happens again.
