How to prevent sheet metal coordinates being exported to DXF?
When I export a sheet metal flat pattern as DXF, the coordinates are exported too.
How can I prevent coordinates being exported?
Thank you.
This is probably SPR 1229251 “Sheet Metal - Export DXF DWG - if ‘view sketches’ is enabled, additional lines are added around the origin”.
Please try to check “Views → Hide / Show → Hide All Types” before exporting.
That was it. Million thanks.
Problem solved.
I searched for the SPR but couldn’t find it. Can you post a link to this SPR?
Thanks again.
https://kbsw.3ds.com/mashup-ui/page/sldwks_kb4cp?q=1229251+&source=customerportal_enu&onesearchpocfeed.r=%2Bf%2Flanguage%2Fenglish
You’ll need a SOLIDWORKS ID to see the SPR.
Customer impact is set to high. At least they know how bothering it is.
We hadn’t any problem in 2021 version. I hope they correct it in sp1.
Thanks for the link.
