How to increase the perimeter in an object...
Hello,
I would like to ask if there is an easy way to increase the perimeter of an object, as shown in the picture below:
without having to recalculate each side.
Thanks in advance for your reply,
Cagoci.
If it’s a sketch, use Offset Sketch. If it’s a set of faces perpendicular to the screen, use Move Face. If it’s a bounded surface, use Extend Surface
The simple answer is “Yes, there is a way to do that.” As matt indicated, we need a little more information to be more specific.
Thank you very much! I forgot to mention its a sketch!
Then when you use the Offset Entities sketch feature you can go to the property manager and choose to have the original lines be switched to construction lines if you want (or the new lines).
