Good day to you all, I’m finally back, after my old company sent me away due to outsourcing quite suddenly.
After all those sheet metal problems (I will write an update fairly soon on those), I’m now with a company, that uses PDM and we would like to lock some parts with a freeze bar and change custom properties to be standardized across the parts.
- Does it make a difference to freeze vaulted parts for the rebuild speed with a PDM system? Most parts are not checked out and are locked into the vault anyway. Or am I wrong here?
- How can I change custom properties to look like
"SW-Material@@configname@partname.SLDPRT"
? Is the only way a macro or do I have other options?
3. The BOMs here are basically done manually and we would like to automate things better. Any literature/courses/videos on this regarding PDM? Any additional best practices on how to deal with different materials from different vendors properly (shape stays the same, material changes, maybe thickness a bit, color changes…)?
