Crosspost from here, so there are google search results:
I was trying to quickly make a macro, that colors a selected edge on a drawing & adds a custom line thickness to it, but I cannot get it to run, because it fails at swThisEdge.SetLineColor 255 - telling me, that this object does not support this property or method.
What am I doing wrong?
Set swModel = swApp.ActiveDoc
If Not swModel Is Nothing Then
Dim i As Integer
If swSelMgr.GetSelectedObjectCount2(-1) > 0 Then
For i = 1 To swSelMgr.GetSelectedObjectCount2(-1)
Debug.Print swSelMgr.GetSelectedObjectType3(i, -1)
If swSelMgr.GetSelectedObjectType3(i, -1) = swSelectType_e.swSelEDGES Then
Dim swThisEdge As Object
Set swThisEdge = swSelMgr.GetSelectedObject6(i, -1)
swThisEdge.SetLineWidthCustom (0.0007)
Next
Else
MsgBox "Please select an edge!"
Else
MsgBox "Open model and select edge!"
Solution:
The code below will do the magic. The error tells you exacly whats is wrong. You’re calling SetLineColor on a SldWorks.> Edge > whicht doesn’t have the method > SetLineColor> , this is a method of SldWorks.> DrawingDoc> .
Option Explicit
If swModel Is Nothing Then Exit Sub
If swModel.GetType <> swDocDRAWING Then Exit Sub
Dim swDrw As SldWorks.DrawingDoc
Set swDrw = swModel
swDrw.SetLineColor RGB(255, 0, 0)
swDrw.SetLineWidthCustom 0.0007
