How Do I get it to machine the complete radius? SW CAM
I just can not seem to get the SW CAM to machine the curve in the attached part
it will do it part way down and then it will stop/END As shown in the Tool path Simulation screen captures.
I would like it to machine all the way thru the part.
Attached here is the part file : shape 49.SLDPRT (320.0 KB)
At first I had the R as a fillet but that had the same problem as I have here with a Swept Cut to form the profile. I Thought modeling it in a different way may help. But No. I Guess I’m doing something else wrong.
Any help would be appreciated.
Thanks
try to ask your question here: CAD / CAM | Practical Machinist - Largest Manufacturing Technology Forum
I don’t used SWCAM, when HSMWorks was killed off I just now use Fusion 360 for CAM.
is there a setting for the tool to be outside the face boundry instead of tool center???
len_1962 thanks for the link,
With you pointer I did figure it out, see below:
