Extracting a .step file from 3DInterconnect
Hello,
I’m facing issues opening a .step file without having 3DInterconnect activated, so I’d like to know, is it possible to extract the assembly structure of a 3Dinterconnected file?
I’d like to be able to extract the file so that I can then lighten it and also create configurations out of it. I generally have no issue and don’t use 3DInterconnect.
Here’s an image to show the assembly structure that’s 3Dinterconnected that I’d like to ‘extract’
I don’t use 3d interconnect either, so this is a shot in the dark. Will this work for you?
https://help.solidworks.com/2021/english/SolidWorks/sldworks/t_break_link_from_original_file.htm
Giving it a try right now!
Issue comes from the file coming from Inventor.
Sometimes when attempting to open .stp files created with Autodesk Inventor, you will get errors.
There should be a log file that will have the same name as the .stp file, but the file extension will be .err
This log file can be opened with notepad in windows, and will look similar to the attached image.
If this happens, open the .stp file with notepad (Rt. Click on the .stp file, select “Open with”, and select “notepad”)
In notepad, Select “Edit” → “Replace”
In “Find what:” type PRESENTATION_STYLE_ASSIGNMENT
In “Replace with:” type PRES
Select “Replace All”
Save the file
Try opening the .stp file in SOLIDWORKS
I was able to break the link, but not save the file, though Todd came to the rescue! I’ve posted the solution for anyone it could be useful for in the future, including me.
Save the Assembly as Parasolid File. Reimport the Parasolid File. Advantage all the sub Parts are fixed.
