Export STL Body from Multibody Part
I want to save the parts separately as STL from a Multibody file, but I can’t find the Save As in the Design Tree. If I go “File: Save As” with one body selected, SW try to save everything as usual…
http://help.solidworks.com/2021/english/SolidWorks/sldworks/HIDD_EXPORT_SEL_DLG.htm?id=5f5b2a156d4a4b1ab1f4f63eeaadfb8e#Pg0
First I saved the files individually using Delete Bodies + Save As, but this resets the STL origins and when importing to Blender they don’t keep the initial position. (it’s for an animation)
So I ended up creating an Assembly, inserted the multibody 4 times, set it virtual and independent, then used Delete Bodies in each part, and finally saved it… -_-
Is there an easier way to do it?
There are few ways to do it:
  1. Macro to export each body as STL.
  2. Select the desired body to save as STL and you should get a pop up window to select the option (refer picture below).
  3. Convert bodies into assembly using save bodies options (https://gupta9665.wordpress.com/2010/11/10/assembly-from-part-no-mates-required/) and then convert the assembly into STL for each part.
I managed to do the third option. Thanks for the instructions, gupta9665 !
About the second one, how can I get this Export option?
The Export option window should automatically come if you have a body selected from the bodies folder.
For some reason I was expecting the Export window to pop up before the Save one ;;
Thank you!!! UU
I thought I read a thread last year where this wasn’t possible. The API doesn’t give you the option to save a single body. If I am wrong about this I would love to find a macro with that functionality.
https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/#community:yUw32GbYTEqKdgY7-jbZPg/iquestion:GsslK7TSQgm1IxCVYERrEA
“Deepak Gupta - 2018-10-22
​/ ​, I do not think that exporting selected body as STL is yet supported via API as I can not get the macro to work on older versions as well.”
The macro in the post on SW forums works OK on 2020 for me. So working with selected bodies can be made.
