Delete Revision tables on all sheets & insert a blank one on the first sheet
Came across something the other day, so here is the quick & dirty (not cleaned up) code for a macro that deletes all revision tables on all sheets & inserts a new blank one on the first sheet.
Modify the
RevTablePath
variable with your template.
Credits go to:
initial code from the SWYM(P) here
Further reading (in German)
Enjoy!
Option Explicit
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swSelData As SldWorks.SelectData
Dim swSheet As SldWorks.Sheet
Dim swTableAnn As SldWorks.TableAnnotation
Dim revTableFeat As SldWorks.RevisionTableFeature
Dim swAnn As SldWorks.Annotation
Dim vSheetNames As Variant
Dim boolstatus As Boolean
Dim bRet As Boolean
Dim i As Long
Dim RevTablePath As String
Dim RevTableAnn As SldWorks.RevisionTableAnnotation
RevTablePath = "C:\your path\your revision table template.sldrevtbt"
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Set swSheet = swDraw.GetCurrentSheet
Set swSelData = swSelMgr.CreateSelectData
vSheetNames = swDraw.GetSheetNames
For i = 0 To UBound(vSheetNames)
    swDraw.ActivateSheet vSheetNames(i)
'    Debug.Print vSheetNames(i)
    Set RevTableAnn = swSheet.RevisionTable
    If Not RevTableAnn Is Nothing Then
'        Debug.Print "Revision Table is SOMETHING! Double check for revTableFeat now!"
        Set revTableFeat = RevTableAnn.RevisionTableFeature
        If revTableFeat Is Nothing Then
'            Debug.Print "Revision table feature is nothing but a revision table exists!"
            Set swTableAnn = RevTableAnn
            Set swAnn = swTableAnn.GetAnnotation
            boolstatus = swAnn.Select3(False, swSelData)
            bRet = swModelDocExt.DeleteSelection2(swDeleteSelectionOptions_e.swDelete_Absorbed)
            Debug.Print "Revision table annotation deleted? " & bRet
        Else
'            Debug.Print "Revision table feature is present! Delete it!"
            Set swFeat = RevTableAnn.RevisionTableFeature.GetFeature
            bRet = swFeat.Select2(False, 0)
    Else
'        Debug.Print "Revision Table is nothing! Sheet can be skipped!"
Next
' Activate first sheet
swDraw.ActivateSheet vSheetNames(0)
' Insert rev table
Set RevTableAnn = swSheet.InsertRevisionTable2(True, 0#, 0#, swBOMConfigurationAnchor_BottomLeft, RevTablePath, swRevisionTable_TriangleSymbol, True)
