i always use this tool to check fillets/radii on model, and most of the time it’s reliable. this morning, anything displayed in red wont show up on the screen next to the mouse pointer. doesnt matter the size, .005, .01, .03 - none of them show up. is there a setting or something im doing wrong? using 2024
I made a 3d sketch with the face curves and it appears it’ll only display the curvature by the perpendicular lines on the face. this is probably normal behavior and i’ve never noticed it until now? does someone have a better understanding of how this works??
bump.
anyone? any thoughts?
Assuming you mean shaded curvature? I have found on a dimensionally large model with small details/fillets, it will not show the curvature/radius when hovering over small surfaces. Sometimes works if you offset the surface first then isolate.
that’s exactly the case here. I appreciate your comment and i’m glad im not the only one that it happened to. thanks!
All good and yeah, frustrating problem!
