Is it possible to change custom properties of a component via API/Macro with only the drawing being open?
Or do I first have to open the component in the background, modify the properties of it and then save & close it again?
Is there a resource-friendly version of opening & closing a component in the background?
I don’t know how to do it, but it most certainly is doable as CustomTools, the add-on we use, does that.
Yes you can. I got a macro that give me the ability to change the properties of a compenent that is selected in a drawing BOM.
How do I do this i.e. from a model referenced in a drawing view?
Do I have to save the referenced document too?
Have you tried Property Tab Builder?
one of the downfalls of the Property Tab Builder is that it does not offer the possibility to edit custom properties on components from the drawing level.
How about creating a custom BOM with the fields you want to change? Then you can edit the fields in the BOM and it would update the parts.
Found the answer:
SldWorks.View.ReferencedDocument
is what I needed.
It is meant to fix legacy parts - so making something new is not an option.
Full macro code to change/add properties to the referenced part from the first view of the active sheet of a drawing.
Option Explicit
Dim swView As SldWorks.View
Dim swDrawModel As SldWorks.ModelDoc2
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
' Start performance enhancers
StartNoScreenUpdate swModel
StartLockFMT swModel
' First view on the sheet (sheet format)
Set swView = swDraw.GetFirstView
' first actual view
Set swView = swView.GetNextView
' set swdrawmodel to be model that is referenced on the first sheet on the first available view
Set swDrawModel = swView.ReferencedDocument
' Exit if drawing has no referenced documents
If swDrawModel Is Nothing Then
MsgBox ("This drawing has no referenced documents!")
Exit Sub
'define what should be changed
Dim propertyName As String
Dim propertyValue As String
propertyname = "some name"
propertyvalue = "some value"
'read out all title block items from drawing
AddProperty swDrawModel , propertyName, propertyValue
' End performance enhancers
EndNoScreenUpdate swModel
EndLockFMT swModel
' adds a property with the name "propertyname" and the value "propertyvalue" to the general tab of the custom properties
Sub AddProperty(swModel As SldWorks.ModelDoc2, propertyName As String, propertyValue As String)
Dim swModelDocExt As ModelDocExtension
Dim swCustProp As CustomPropertyManager
Dim newprop As Boolean
Set swCustProp = swModelDocExt.CustomPropertyManager("")
newprop = swCustProp.Add3(propertyName, swCustomInfoText, propertyValue, swCustomPropertyReplaceValue)
' Speed up the macro!
Sub StartNoScreenUpdate(swModel As SldWorks.ModelDoc2)
Dim modView As ModelView
Set modView = swModel.ActiveView
modView.EnableGraphicsUpdate = False
Sub EndNoScreenUpdate(swModel As SldWorks.ModelDoc2)
modView.EnableGraphicsUpdate = True
Sub StartLockFMT(swModel As SldWorks.ModelDoc2)
swModel.FeatureManager.EnableFeatureTree = False
Sub EndLockFMT(swModel As SldWorks.ModelDoc2)
swModel.FeatureManager.EnableFeatureTree = True
