Be Active - please...
That’s a pretty general question. You might have better luck posting a specific question (unless I’m completely misunderstanding something).
One year isn’t a lot. There’s a pile of stuff in the software, and after almost 30, I still don’t know everything (and I’ve forgotten half of what I did know). Coming here is a good start. Ask questions that confuse you. Read Mastering Solidworks, but seriously, there’s a lot of good stuff in there, not just the stuff from the SW training.
Hopefully this doesn’t come across as snarky. As far as Solidworks is concerned, lower your expectations. It is slow on the best hardware. It crashes / hangs fairly regularly. A lot of this can be avoided by following better practices, but even then, it has issues.
Customer: “It’s slow and doesn’t work right.”
VAR: “Oh, your not doing it right you have to use a different workflow. It’s as simple as remodeling everything.”
Customer: o[ grumph :angry:
Edit: This why they don’t specify a best workflow.
I was told that in order to make pack and go work properly, we had to completely redo our folder structure. (To one that is not possible in our organization.)
1. > Pack and go works best when no more than 3 folders separate the top level assembly from the furthest away component. This 3 level folder separation must be done vertically in the directory tree. Similar to the example below
…a. Top level
…i. Sub assy 1
…ii. Sub assy 2
…1. Sub assy 2.1
2. > Pack and go usually has difficulty with success if it has to navigate out of the top level folder into another main directory or over a network to gather all parts
(ignore all of the periods. That is the only way I could get the indentation to layout properly on the fourm.)
I’m surprised to see that. Pack and Go works just fine for me, and I often have project specific files on one network drive and my library parts and sub-assemblies on another one.
Ok, the “or else” was a bit much, so I changed that. Unless you’re using the Breeze theme, in which case you may never see the change.
Hi there,
Looking for places to learn about how to work with CAD and not finding answers on Reddit. Thought this would be great - so far, learning a ton. As we speak, I’m designing my new shed in AutoCAD :stuck_out_tongue:
J
I was wondering where the familiar names of CAD past had disappeared to following the demise of the SW boards (enough has been written about that).
22 years of SWx including 16 as a freelancer, now considering something new (to be posted in the Agnostic board)
A few of them just didn’t have the same feeling on here as they had on the previous SW Boards, unfortunately. But, for the most part the community is still thriving.
