Attach Leader Center as Default
Hello,
After a drawing note has been inserted, it is possible to change the leader option to “Attach Leader Center”. Does anyone know if this can be changed somewhere in the document properties? I would like to make it the default in our drawing templets.
It cannot. There is an SPR:
SPR # 1023142
Product SolidWorks
Status Open
Fixed in none none
Area Drawings
Sub-Area Annotations - Drawings
Customer Impact Medium
Add the ability to have ‘Attach Leader’ options for multi-line notes set to a default selection in document properties
I don’t understand why, but there are tons of things that you cannot set a default for in Solidworks.
Many things can be set by modifying it and then saving a new template. But I am not sure if that is one of the things because it is a pain in the neck to do.
Some of these can be set under Options/Document Properties/Note but not this one.
