API Set Component Display States From Folder Selection?
I’m trying to automate setting the visibility (Hide) of components in various display states. The components are grouped in Folders. I’m able to set each component one at a time using the following:
SetVisibilityInAsmDisplayStates Method (IComponent2)
http://help.solidworks.com/2021/english/api/sldworksapi/solidworks.interop.sldworks~solidworks.interop.sldworks.icomponent2~setvisibilityinasmdisplaystates.html
This method takes a long time as each component is set one at a time. If I were to do this manually, I would select the folder, and select Hide and all the components in the folder are hidden immediately altogether.
How can I do this through the API in VBA? I can’t seem to find a method.
SW2021SP2
That is because the folder is considered a component not a special container. So something like this will work.
boolstatus = Part.Extension.SelectByID2(“FOLDERNAME”, “FTRFOLDER”, 0, 0, 0, False, 0, Nothing, 0)
Part.HideComponent2
Part.ShowComponent2
